Brief Description: Canopy work - mid stop, latch, center rail
-Drilled the mid canopy stop hole for the latch pin to drop into. -Reworked the main canopy latch hook. It was putting too much force latching the canopy shut so I releaved it slightly. Now it's much better and less scary! -Located the center rail canopy pin receptacle block. The pin engages this block when you latch it shut the last1/2" of travel. Located the mounting holes and pilot drilled it and then removed it and drilled and counterbored it per the plans on a drill press. (pic 2) -Bolted it in place (pic 3)
