-Did some more work on canopy closure. It is getting better and the skirt is more flush in the back. I need to work on the teflon receiver block as it is partly keeping it open. -Riveted in the retainer block bracket -Located and laid out the access cover hole for the smoke oil tank (to refill)
5" diameter hole in the top of the turtle deck
The bottom 3 rivets in the U pattern were put in. They are pull rivets as there is no access.
