Brent s RV-8 Project N784DE
Date:  12-16-2010
Brief Description:  Fwd Baggage Door #20 +
Matt Dralle of Matronics was kind of enough to point this baggage door strut tip out. He gives you the vendor, part#s and exact mounting locations! Thanks Matt!
-Marked the hole locations in the door and the firewall support. Drilled them out. The bracket on the strut needed to be opened up very slightly to accept #8 screws - don't use a drill, the stainless will grab and tear up the world, just use a dremel with a rotary file.
-Mounted the nutplates in the firewall support
-Riveted the strut to the door
-Screwed the strut to the support.
Works perfect. It holds it open and goes overcenter when closed to which hold the door down slightly - too cool!
With my extra time I worked on the manifold pressure line. Put on the aeroquip fitting and put the steel 45 on the engine (I removed the previously installed allum straight fitting).
Full open
Full open
Front inside - not it goes overcenter
Manifold pressure fitting
