Brent s RV-8 Project N784DE
Date:  11-19-2008
Number of Hours:  1.00
Brief Description:  Flap mounting #9
Well these flaps are going on forever! I can't wait until they are done. It's mostly because I keep working in short spurts. I cut out the 4 hinge eyelets that will capture the hinge pins (2 on each flap) as a retainer once they are installed. See picture from Mike's installation on his RV-7. I drilled the hole for the number 8 screw. After work I primed the hinges down in the barn - it was dark out so I needed the lights. Cold too - 30ish! Took awhile for the primer to dry.
Mike's very clean flap hinge pin retainers.
Cutting the hinge eyelets away on the bandwaw.
Here's all 4 ready to go. The lower ones are laying as installed and the upper two are lose.
