Brent s RV-8 Project N784DE
Date:  11-16-2008
Number of Hours:  2.10
Brief Description:  Flap mounting #7
Again I didn't get up as early as I'd like, the winter is making me hibernate! I did manage to finish drilling the right wing flap hinge to the right wing flap and then get everything hoisted up onto the wing and to locate the hinge on the wing. Once that was done, I lowered the flap down on the straps and drilled the wing side of the hinge. I started dimpling the right wing skin when I had to knock off. Good progress anyway. As an aside, I mounted my new electric forced air heater, but I didn't get it wired yet, hopefully this week as the temps are starting to drop.
Upper hinge is clamped and ready to drill. Note the flap is hanging down below and tilted
Test fitting after the holes are drilled but before riveting.
The trailing edges are lined up pretty good and note the 1/4
The trailing edges are lined up pretty good and note the 1/4" drill bit for the req'd spacing.
