Brent s RV-8 Project N784DE
Date:  2-2-2008
Number of Hours:  1.50
Brief Description:  Prepping bottom wing skins #5
This morning I taped off the wing skins for priming. I only prime the inside surface, but to avoid an overspray mess, I tape off the edges and the rivet holes. I then cleaned them with acetone and shot them with 7220 primer (2 coats). It was about 30F, but this stuff doesn't seem to mind - just dries slower. Between coats of primer, I riveted the nutplates onto the pitot tube mast base.
One of the outboard skins taped off and ready to prime.
Between primer coats I riveted the nutplates onto the pitot tube mast.
Here are the left wing skins drying on the bench.
