I had removed the fuel tanks to facilitate finishing up some riveting on the main wing ribs and also for torquing (sp?) down the tie down brackets (you can't access them with the tanks on). So now that those things are done its time to put them back on. Syd came out to help. I didn't quit get down before I had to run, but I got most of the hardward started and I will torque (bolts) and tightend (screws) next session. Now my workbench is clear for me to do the pitot mast layout on the bottom outboard left wing skin. This is the one item I don't have to do twice (pitot is only on the left wing).
Putting the bolt in the "Z" brackets for the left fuel tank with Syd handing me the hardware.
