Not a real productive session this morning. I need to do a lot of random stuff to get to my goal of getting the aileron actuation system installed. I had to remove the fuel tanks to access (I needed to anyway for some rivets that I didn't install in the rib-to-spar flange area) the wing tie down brackets so they could be torqued and then I could work on installing the bellcrank attach brackets. I also spent some time locating all of the hardware, removing labels, etc.
Fuel tanks removed.
Hardware for the bellcrank located and sorted
Torqued and torque locked the tie down bracket nuts (25in lbs).
