Brief Description: Drilling the fuel tanks part #1
Satisfied with the fuel tanks I began by drilling the joint plate to fuel tank screw holes on both wings and the root rib to Z brackets. Then I removed all the cleco's holding the leading edge on - be sure to un-cleco the inboard rib where the joint plate is and removed the leading edge without it as you can remove it later. I then drilled out the outboard rib on the left wing and removed the fuel tank. Tomorrow I will finish drilling the left wing and move over to the right wing.
Drilling the root rib to Z bracket ont the left wing.
Fuel tank removed except for the end ribs and the rear baffle.
