Mitchel got up early with me this morning before work/school and we attached the Z brackets in preparation for tank fitment. After that was done we put the tanks on both wings. Looks like I have a little mis-alignment on the left tank so I will check to be sure the spar is level and then pull the tank down flush with some motorcycle straps before I drill any of the mounting holes. Hopefully those two things will take care of any misalignment between the tank and the leading edge section. It is awesome to see the wing in it's mocked up form.
