Brief Description: wings trued and leveled in the jig
I spent 20 minutes making sure the wings were level and there was no twist. I dropped a plumb bob down from the spar on each end of the wing and measured the distance between the string and the rear spar to see that it was the same on both ends before I clamped the trailing edge into the jig.
Plumb bobs down on each end of the wing to check for twist
