Brief Description: Fabricating tie down brackets/spacers/etc
Worked today on fabricating the tie down brackets that anchor to the spar, They also do duty as support for the aileron bellcrank attach brackets. It was farely straight forward, but I wasn't on my game today so progress was slow. I got them primed and ready for riveting (spacer to tie-down) then they will bolt to the spar along with the airleron bellcrank brackets.
Mary came out to help! You can see the silver tie down bracket in the foreground.
Drilling the holes in the tie bracket and spacer for nut plates.
