Brent s RV-8 Project N784DE
Date:  1-27-2007
Number of Hours:  1.20
Brief Description:  Riveting nut plates onto the inboard spar web
Short session today. I need to mount two nut plates to the inboard section of the spar web on each spar (4 total). I had to counter-sink the rivet holes per plans and prime the counter-sink (removed anodizing) hole. I then riveted the nut plates on. I ended up removing two rivets I was not happy with (I had to buck these rivets and my technique was slightly rusty), no big deal.
Front side of the spar web got these two nut plates.
Here's the other side, the gray area is primer.
