Started on the Vertical Stabilizer this morning @ 5am. Cleco'd the rear spar @ spar reinforcement with rudder hinges. Drilled them to size. Cleco'd the ribs and spars together and drilled to size. Cleco'd skin onto the skeleton (sub structure). Next step is to match-drill the skins to the sub-structure. Fast progess and having fun now that the learning curves isn't so steep.
