Brent s RV-8 Project N784DE
Date:  11-18-2009
Number of Hours:  0.80
Brief Description:  Elevator / Horizontal Stab Tips #5
Glassed the leading edge of the elevator tips with one layer of cloth. Let it cure and tomrrow I can sand and put on micro to get a finsihed surface.
I also finished riveting the nutplates onto the HS tips and I screw'd the right one on before i ran out of time. My buddy Greg is bringing some foam to work so i can work on capping off the HS tip.
Left tip prior to peel ply
Right tip with peel ply
Rt HS tip, not it is slid out slightly to better align it with the elev horn - I'll fill that later
