Brief Description: Tail position light wire location
Put the vertical stab into place temporarily to work out where the tail position light on the rudder will exit the tail. From what I could tail - no pun intended most folks ran it below the bottom hinge, but I wanted to avoid the tailwheel mount so I did do it below the hinge, but off to the side. Drilled a 1/4" hole and put in a plastic grommet.
