Short session this morning. I am starting to work on a circuit breaker panel for the right side console. I attached the center section bulkhead cover on the right side with clecos and the right side switch panel. Then I took measurements and cut out a cardboard template. I forgot to account for the angle of the gear tower in relation to the side console so there is more work to be done. I'm off to work.
