Fabricating the mounts for the andair fuel valve. Located it forward of the valves position. I used 3/4 x 3/4 aluminum angle. Cut them to length and drilled and countersunk the applicable holes. I will make them removable.
Andair fuel valve with angle stock that I'll use to mount it.
