Brief Description: Fuel Filter and Fuel Pump Brackets
Match drilled for CS4-4 blind rivets the bracket that holds the airflow performance fuel pump and the fuel filter. Then I deburred and countersunk the same. Then I primed them along with a couple of other random parts that needed priming. Also drilled out the most forward inboard rivet on the forward side of each gear tower so I could install the ground adjustable rudder pedal tracks.
The brackets are just under the pump and filter.
Here's a bracket ready for priming -the CS4-4 is also shown.
