Brief Description: Control System Installation #14
-Removed the up elevator control stop bracket. -Fabricated the spacers to the F841 to elevator horn attachement. -Bolted up the horn at the F841 and the center bracket/bearing.
Spacers for the F841 push rod to elevator attachement
Since the airplane is right where you walk out the garage door, I put this foam on the trailing edge
