Brief Description: Adding Tailcone to FWD Fuselage #2
Since my order of 250 clecos came in I finsihed cleco'ing the tailcone bulkheads. Several of the ones on the bottom needed to be lined up with a pick or an awl to get those tabs lined up with the skin holes. No biggee but made for slow work. I then cleco'd the bottom mid-fuse skin to the bottom tailcone skin - easier than I thought it would be.
I then set my right longeron in place per the plans and it looks pretty good. I may need to tweak it alittle, but we'll see.
On my back cleco'ing the bottom of the tailcone to the tailcone bulkheads.
Clecoing the bottom aft edge of the mid fuse skin to the bottom fwd edge of the tailcone skin.
