I cleco'd the outboard left wing skin which ended up taking over an hour due to the pitot static hardware and redoing the scarf joint where the inboard and outboard meet - I wasn't happy with the fitment so out came the grinders. I then touched up my primer where I ground it off and re-cleco'd everything together in preparation for riveting. Mitchel and I are shooting for Tuesday to get out there and get most of it on. I need to move the wings into the crades so I can attach the flaps and take the stands out of the floor. I re-measured the twist and I have maybe 1/64" of twist between the inboard and outboard sections - pretty good as its hard to see that on a measure with out paralax causing you to read it differently.
Cleco'ing the left wing outboard bottom skin.
Closeup of the pitot tube mast with the pressure line sticking out.
Outboard skin cleco'd on. Not a good angle but I'm running out of room to work much less take pictures
