Continued work on the trim tab. I located and match drilled the riblet holes for each end of the trim tab to close it out. I then disassembled everything and machine countersunk the top of the trim tab "spar". Not alot done, but good progress in a short amount of time.
Match drilling the outboard riblet hole.
Machine countersinking the top of the trim tab "spar"
