Continued to work this morning and cleco'd the rear spar into place and cleco'd the end ribs (root and end) to the skins. The only riveting left is around the edges so I get to squeeze these (which is always preferable to bucking rivets with a rivet gun as it is much more controlled). Squeezed all the rivets into the end ribs on the RH side (top and bottom) and I have the inboard ribs riveted on the LH side. Not much more to go and this sub assembly is done!!!!
Cleco'd end ribs and rear spar to H stab assembly - this is were I need to rivet (top and bottom)
Squeezing rivets to attach the "root" rib to top of H stab skin -very easy once you get a technique
Order of Riveting - Red 1st, Blue 2nd, Green 3rd, Brown - Final riveting to close it up (rear spar)
