Up early and in the shop at 6am this morning. Blind riveted the center ribs to front spar per plans (HS707/708 to HS702). Riveted the end rib (HS706 to the end of the front spar (702) with universal rivets. Then started flush riveting the bottom skin on the LH horizontal stabilizer. Went well, good process for an hour of work. I'm about 3/4 of the way finished with the bottom skin and then I flip it over and repeat. Once that is done, I will wait for a tech inspection (Rick Blaes) before I close out the piece by riveting the rear spar in place and in the mean time I'll start the right side HS.
blind rivets (pop) tying the center rib/nose rib and front spar
Riveting end rib (HS706) to the front spar
Riveting the bottom skin to the front spar and center rib
