Sydney helped me finish up the rear spar reinforcement rivets - everything went good, just time consuming. Started on riveting the elevator attachment brackets to the rear spar. The rivets are taller on the outboard brackets so I stood one over on the first rivet, drilled out and the others 3 went good. About another hour to go on the rear spar and I'll move on to the front spar.
