Brief Description: F-804 L Bulkhead Cover Modifications
-Needed to relieve the cover for the rear throttle rod. -Needed to cut out the cover plate and opening for servicing the cockpit light and switches that I wouldn't be able to get to after the cover is blind riveted into place. -Drilled for #8 nutplates and installed the same to accomodate my manual aileron trim bracket attachment.
Bulkhead cover ready for more modification
The cover lives just behind the throttle quadrant
Opened up for access. A cover plate cover over the top
