-Stole this idea off VAF to avoid dragging brakes, which are very bad!!! Ordered the springs and collars from McMaster-Carr - cheap, fast, and easy - just the way I like 'em.
-Also put an Adel on the pitot heat wire at the aileron bellcrank. -Riveted the aft fuselage access cover attach brackets (now I need to prime it).
Aft fuselage access cover attach brackets riveted on.
