Jumped around abunch today -Located and mounted the manifold pressure sensor on the side of the GPS shelf. Still need alittle hose clamp for the hose to hook to the sensor. -Located the blast tubes for alternator, each magneto, and the fuel pump. Drilled them to 11/16 with a unibit and installed the tubing. I am leaving it loose for now. -ACS sent the little adel clamp I needed to attached the cable sheath so I finished the alt air door installation. -Trimmed the avionics access door to clear the support for the modified baggage door skin addition. -Put the steel AN nipple fittings on the red cube. I ordered the wrong hose ends so I can't complete the installation for now. -Started removing the prop bushings using my engineer friend Mike Cencula's elegant removal tool - works great Mike! I ran out of time, but the first one came out with ease.
Manifold Pressure Sensor (MAP) on the GPS shelf
Manifold pressure tapped into the #4 cylinder
GPS shelf and MAP sensor with hose on the firewall.
