-Trimed and fitted the right wheel pant to match the left. I ended up having to redo the holes I drilled into the outer support bracket twice trying to get that one aligned properly - I thought the second one would be easier? Thank goodness it's fiberglass and not aluminum in this case. Anyway, I have it like I want it and I have everything layed out to square them up and drill the inboard brackets which will set the final horizontal and vertical alignment.
Right wheel pant on and drilled (outboard bracket)
