-Did some additional trimming on the aft left wheel pant for the gear leg and then drilled the 4 holes that attach it to the outboard bracket (after aligning the pant vertically and horizontally) -Trimmed the fwd section for the tire and gear leg and cleco'd into place
-Layed out a centerline on the airframe to square up the left and right pants before I drill the inboard brackets.
Next is to fit the right pant and then I can finish attaching them both.
So far this hasn't been too hard.
Drilling the left pant for the outboard bracket
Here's the fwd plumb bob and the centerline on the floor that bisects the aft plumb bob.
