Brent s RV-8 Project N784DE
Date:  3-2-2010
Number of Hours:  1.00
Brief Description:  Installing E-bus rectifier and Flap Relay
-After some head scratching I figured out where I wanted the e-bus rectifer to mount. It comes on a big heat sink so it takes up some room. I also located drilled the holes for mounting the flap relay right next door. I mounted the rectifier but ran out of time to mount the flap relay board.
The black box is the rectifier
