Brent s RV-8 Project N784DE
Date:  3-1-2010
Number of Hours:  1.40
Brief Description:  Wiring Interior Lights #6
-Finished wiring up the aft bagg light
-Located and drilled the holes for the dimmer knobs.
-Mounted and wired the same on the front of the left gear tower in front of the throttles
Tested the system and everything worked as advertised. I almost though I had a problem with the cockpit map light, but then I realised the dimmer was turned all the way down - duh! Happy to have this system in and functional. Now I need to get the buses and switches installed for the other systems and started organizing the various bundles.
Panel lights on -that is the L and R console and the eyebrow strip lgt above the panel- not installed
Here is the map light on in white - it will switch to red too.
Wires everywhere!
Wires everywhere!
