Dan's Web Site
Date:  9-9-2009
Number of Hours:  0.50
Brief Description:  Mark Front Baffles for Further Trimming
I decided to install the top cowl to see how well the airseal material was mating up against the cowl. Everything was looking good.
However, I did have a tough time actually dropping the front of the top cowl down over or rather inboard of the side baffles now that the fiberglass inlet ramps have been epoxied onto the top cowl. I decided to use a sharpie to mark the new contour of the inlet ramps on the side baffles for further trimming. This should make it easier to install and remove the top cowl and should also make it a bit easier to install the airseal strips.
Left front baffle - marked for final trimming to match contour of inlet ramp
Left inlet - airseal material tight against the top cowl
