Brief Description: Install Right Front Inlet Corner Assembly
The final riveted front right inlet corner assembly (parts 9, 10, and 11) was then installed on the engine. I thought it would be more difficult installing this relatively large assembly around all of the engine components but with the right twists it dropped in just fine. The fit is pretty good,,,I still need to trim the top edges of the bulkheads for the top cowl.
