Brief Description: Fabricate Diagonal Support Angle for Part 8
I forgot to fabricate and install the diagonal support angle on the aft right side baffle - part 8 so that's what I worked on today. The support angle is made from 0.032 3/4x3/4. This was then drilled to the baffle and then everything was deburred. The inside face of the baffle was countersunk for flush rivets. Everything was then cleaned with acetone and then alodined.
0.032 support angle and part 8 drilled, deburred, and alodined. Part 8 has also been countersunk
