Brief Description: Install Stop Bracket, Zerk Fitting, & Allen Stop S
Today I reamed the holes in the swivel stop bracket and nose gear leg to 0.311 and then installed the bracket with an AN5-17 bolt and an all-metal lock nut torqued to 90 in-ibs. I also installed the zerk fitting and the two allen stop screws using some high-strength loctite.
Ream nose gear leg and stop bracket to 0.311 and install with AN5 bolt
Zerk fitting and Allen stop screws installed with Loctite
