Brief Description: Micro Over Fiberglass - Firewall Edge of Top Cowl
Today I sanded the fiberglass strip covering the rivet holes along the aft firewall edge of the top cowl, cleaned everything, and then added a thin layer of micro. I also experimented with using a single edge razor blade to squeegee some straight epoxy into some of the pinholes on the top cowl. Van's recommends this method but I have heard others say this makes for some difficult sanding later. We'll see how well it works on a small area.
Thin layer of micro added over the fiberglass strip covering the rivet holes for the old hinge.
