Brief Description: Trim, Bend, Drill, & Countersink Left Camloc Strip
I decided to trim the firewall edges of the left and right camloc strips to match the contour of the bend in the firewall and to allow the forward edges to the strips to match up with the forward edge of the center strip. I also pre-bent the side strips to match the curve of the skins. Once that was done I drilled the left strip to the firewall flange and then countersunk to accommodate the dimpled firewall flange.
Left camloc strip trimmed, bent, and drilled to firewall
