Brief Description: Drill Inlet Duct Ramps to Top Cowl
Next I drilled the inlet duct ramps to the top cowl. These are just temporary holes that are needed to clamp the ramps in place while they get floxed in place. I decided to check the fit of the top cowl with the ramps just clecoed in place before permanently epoxying them in and good think I did. The outboard edges of both ramps interfered with the baffles. I need to trim about an inch off of each ramp before epoxying them to the top cowl.
Inlet duct ramps drilled to top cowl
Outboard edge of right duct needs to be trimmed to fit around the baffle
Outboard edge of left duct needs to be trimmed to fit around the baffle
