Brief Description: Drill 1/4" Holes in Cowl Hinges for Micro
Today I drilled 1/4" holes in the bottom hinges of the lower cowl to provide additional adhesion for the micro that I'll be using to help secure the hinges in addition to the rivets. I also sanded both the hinges and cowl with 80 grit and cleaned with acetone.
Bottom cowl hinges with 1/4" holes and sanded for micro
