Brief Description: Solder First Ray Allen G205 Stick Grip
Today I soldered up one of the Ray Allen G205 stick grips. This grip has 4 switches on top that will be used for the elevator and aileron trim and another trigger type switch on the front for the PTT- push-to-talk function. This really wasn't that difficult to solder given how small the wires are and how tight the quarters. I was pleasantly surprised at how quick and easy this was. Once all of the soldering was done I labeled each wire and screwed the two halfs back together.
