Brief Description: Connect Right P-Lead / Ground to Right Mag
Next I repeated everything for the right P-lead and used the heat gun to attach another solder sleeve / pigtail to the shield on the mag end of the right P-lead, crimped ring terminal's to the ground wire and P-lead primary wire, and then connected these to the right mag.
P-lead for right mag with solder sleeve and ring terminals attached
