Dan's Web Site
Date:  5-27-2007
Number of Hours:  1.00
Brief Description:  Drill Holes in Firewall for Wires; Install Alt Fld
I decided that I'll drill three holes in the firewall for wires; one for the power lines, one for the sensors, and one for the p-leads that run from the ignition switch to the mags. I drilled the first two today,,,the hole for the wires to supply the power to the busses on the right side and the hole for the Dynon EMS sensor wires on the left. The one wire going through the hole for the power is the 18 awg alternator field wire that runs from the alternator to the voltage regulator. I also installed the final 18 awg wire on the regulator end that will eventually run to the master switch. All of the regulator wires are now installed installed at least at the regulator end. I still have to solder the two 22 awg low voltage wires to the lamp and connect the 18 awg field wire to the master switch.
Hole in right side of firewall for power lines
Hole in left side of firewall for sensor wires
Voltage regulator with alternator Field wires connected
