Brief Description: Install Spike Catching Diodes on Relays
Today I installed the blue spike catching diode on the started diode. It runs from the S post to ground,,,which is kind of a tight fit. I may need to lengthen the wire to provide a better fit. The yellow diode on the battery relay fits fine.
