Dan's Web Site
Date:  1-10-2012
Number of Hours:  1.00
Brief Description:  Right Wing Tip - Cutout for Whelen Position Light
I used the dremel to make the cutouts for the Whelen position light. A cutoff wheel worked well for the straight cuts and a cutting bit and sanding drum worked well everywhere else. I know the green position light belongs on the right wing tip but at this point it doesn't matter since the profiles of both lights are the same.
Right wing tip - cutout made for Whelen position lightt
Right wing tip - Whelen position light base clecoed in place
Right wing tip - wrong position light :-) but the profiles are the same!
