Brief Description: Adjust and Tighten Exhaust Pipes
In addition to recharging the large dessicant plugs for the tail pipes, I also installed the lower cowling and spent some time centering the exhaust pipes between the engine mount/nose gear and the fiberglass cowling. Most of the flexible exhaust mount bolts have been tightened. I'll have to tighten the remaining bolts the next time I remove the lower cowl again.
Left exhaust pipe positioned, secured, and dessicant plug recharged
Right exhaust pipe positioned, secured, and dessicant plug recharged
Both exhaust pipes positioned, secured, and dessicant plugs recharged
