Brief Description: Need Washers/Spacers for Lower Center Engine Mount
It looks like I will need a couple of large washers for the lower two center engine mount holes. There is quite a gap between the mount and the firewall at these points. The plans/instructions say this may be needed on some installations. I'll also have to order 2 longer bolts.
The 2 lower center engine mount holes will require some large washers between the mount and firewall
