Dan's Web Site
RV-7A
Electrial
6-11-2007
Connect Dynon EFIS & EMS Power / Grounds
Today I wired up the Dynon EFIS and EMS main power, keep-alive power, and ground leads.
The two main power leads each connect to a 2 amp fuse on the E-buss while the two keep-alive leads each connect to a 1 amp fuse on the battery buss.
Dynon EFIS and EMS main power leads each connected to the E-buss with 2amp fuses
Dynon EFIS and EMS grounds
Dynon EFIS and EMS keep-alive power leads each connected to a 1amp fuse on the battery buss
RV-7A Home
2363
Ailerons
Assembly
Baffles
134
110
Big Dig
Brakes
Canopy Frame
144
152
Cowl
68
74
Electrial
120
96
96
Elevator
Filtered Air Box
Flaps
Forward Fuselage
460
Gear
Hangar
Hardware
Horizontal Stabilizer
Left Aileron
Left Flap
Left Fuel Tank
Left Wing
90
117
Panel
Photo Shoot
25
Right Aileron
Right Flap
Right Fuel Tank
43
60
Right Wing
84
Rudder II
Seats
Service Bulletin: No
Spinner
Systems
Training
Vertical Stabilizer
146
