Dan's Web Site
Date: 3-30-2007
Number of Hours: 2.00
Brief Description: Install Parking Brake, Carb Heat, Throttle, Mixtur
The final task for today was to install the parking brake, carb heat, throttle, and mixture cables onto the panel. Looking good,,,looking good! Just for fun I also plugged the Approach Systems harnesses into the instruments and avionics. These will lessen the amount of wiring that I will need to do but there is still a lot ahead.
Parking brake, carb heat, throttle, and mixture controls all installed on panel
Approach Systems harnesses attached to instruments and avionics
